Control Panel
v3.1
ONLYOFFICE Control Panel changelog
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Introduction
Authentification unique ou Single Sign-On (SSO) est la fonction qui permet aux utilisateurs de s'authentifier une seule fois et d'obtenir accès à plusieurs applications/services autorisés sans contrainte de renseigner à nouveau les informations d'identification.
Quand un portail web comprend plusieurs sections indépendantes (forum, chat, blogue etc.), une fois connecté à un service, l'utilisateur est automatiquement connecté aux autres et n'a plus besoin de se connecter aux différentes applications une par une.
La technologie d'authentification unique repose sur l'opération conjointe de deux applications: le fournisseur d'identité et le fournisseur de service (ci-après dénommées IdP et SP). L'authentification unique ONLYOFFICE SSO est réalisé uniquement en tant que fournisseur de service (SP). Plusieurs fournisseurs peuvent agir en tant que fournisseur d'identité (IdP), mais cet article examine la réalisation Shibboleth .
Si vous souhaitez utiliser l'authentification unique pour connecter ONLYOFFICE Desktop Editors à votre ONLYOFFICE Workspace, désactivez Salles privées depuis le Panneau de configuration.
Préparer la configuration de ONLYOFFICE Workspace SSO
- Installez ONLYOFFICE Workspace v. 11.0.0 pour Docker ou bien toute autre version ultérieure prenant en charge SSO.
- Ajoutez un nom de domaine, par ex. myportal-address.com.
- Sur votre portail, passez à Panneau de configuration ->; HTTPS, créez et ajoutez le certificat letsencrypt pour le chiffrement du trafic (pour activer HTTPS sur votre portail).
Créer le fournisseur d'identité Shibboleth
Exigences
Pour créer, configurer et démarrer le fournisseur d'identité Shibboleth, veuillez télécharger et exécuter le script install.sh.
Ce script réalise les opérations suivantes:
- téléchargement des fichiers docker pour créer des images du fournisseur d'identité et des conteneurs Shibboleth sur github,
- modification du domaine par défaut idptestbed.edu en définissant le domaine spécifié pendant l'exécution du script dans des fichiers de configuration,
- accord de l'accès via le protocole SAML pour le domaine spécifié du fournisseur de service ONLYOFFICE,
- spécification des attributs qui sont requis par le fournisseur de services ONLYOFFICE pour récupérer des données des utilisateurs du fournisseur d'identité Shibboleth (paramètres Mappage d'attributs),
- création et configuration de LDAP et création des utilisateurs à récupérer,
- activation du chargement dynamique de métadonnées du fournisseur de services ONLYOFFICE au fournisseur d'identité Shibboleth,
- activation de Shibboleth SLO, le cas échéant.
- Téléchargez le script install.sh:
curl -L https://bit.ly/3fwo5e6 -o install.sh
- Rendez le script exécutable:
chmod +x install.sh
- Exécutez le script en remplaçant les paramètres:
./install.sh -id your-idp-domain.com -sd myportal-address.com --no_slo
Paramètres du script:
- -id - le nom de domaine de la machine actuelle pour le fournisseur d'identité Shibboleth.
- -sd - le nom de domaine où le fournisseur de services ONLYOFFICE est déployé.
- --no_slo - pour désactiver Single Logout dans le fournisseur d'identité Shibboleth (paramètre facultatif).
- Attendez jusqu'à ce que le fournisseur d'identité Shibboleth se démarre après l'exécution du script.
- Pour vérifier si le fournisseur d'identité Shibboleth s'est démarré correctement, suivez le lien https://your-idp-domain.com/idp/shibboleth depuis votre navigateur. Le contenu du fichier XML doit s'afficher.
- Copiez le lien dans le champ https://{your_idp_domain}/idp/shibboleth par ex., https://your-idp-domain.com/idp/shibboleth) et passez au portail ONLYOFFICE, connectez-vous en tant qu'administrateur. Accédez à Panneau de configuration ->; Authentification unique.
- Assurez-vous que vous êtes connecté à votre Panneau de configuration ONLYOFFICE en tant que l'administrateur et cliquez sur l'onglet SSO dans la section Paramètres du portail sur la barre latérale gauche.
Il est possible d'enregistrer un seul fournisseur d'identité pour votre société sur le portail ONLYOFFICE.
- Activez l'option Activer l'authentification unique et collez le lien que vous avez copié dans le fournisseur d'identité Shibboleth dans le champ URL vers le fichier XML de métadonnées fournisseur d'identité.
- Appuyez sur le bouton flèche vers le haut pour télécharger des métadonnées fournisseur d'identité. Le formulaire Paramètres du fournisseur de service ONLYOFFICE sera rempli automatiquement avec les données depuis le fournisseur d'identité Shibboleth.
Parce que nous avons désactivé lors de l'exécution du script install.sh en spécifiant --no_slo
, le champ URL du point de terminaison de déconnexion unique IdP sera vide.
- Une fois les métadonnées chargées, deux certificats seront ajoutés dans la section Certificats publics du fournisseur d'identités. Une fenêtre de dialogue s'affiche avec le message suivant: Plusieurs vérifications de certificats ldp ne sont pas supportées. Veuillez laisser le certificat principal seulement.
Il faut supprimer le deuxième certificat dans la liste et laissez uniquement le premier certificat car c'est le certificat primaire. Utilisez Supprimer à côté de deuxième certificat pour le supprimer. Si vous ne supprimer pas le certificat, il ne sera alors pas possible de sauvegarder des modifications.
- Vous pouvez saisir n'importe quel texte dans le champ Légende personnalisée du bouton de connexion pour remplacer le texte par défaut (Single Sign-on). Ce texte s'affichera sur le bouton de connexion au portail avec le service d'authentification unique sur la page d'authentification ONLYOFFICE.
- Maintenant, il vous faut créer les certificats auto-signés ou ajouter d'autres certificats dans la section Certificats du fournisseur de service.
Important!Dans la liste Utiliser pour, sélectionnez signature et chiffrement, car le script install.sh a réglé le fournisseur d'identité Shibboleth à vérifier des signatures numériques et à chiffrer des données.
Vous devriez obtenir presque les mêmes résultats:
- Dans la section Mappage d'attributs, synchronisez les données du module ONLYOFFICE Personnes avec les attributs des utilisateurs renvoyés par le fournisseur d'identité Shibboleth.
First Name |
urn:oid:2.5.4.42 |
Last Name |
urn:oid:2.5.4.4 |
Email |
urn:oid:0.9.2342.19200300.100.1.3 |
Location |
urn:oid:2.5.4.7 |
Title |
urn:oid:2.5.4.12 |
Phone |
urn:oid:0.9.2342.19200300.100.1.41 |
Dans la section Paramètres avancés, vous pouvez activer l'option Masquer une page d'authentification pour masquer la page d'authentification par défaut et rediriger automatiquement vers le service d'authentification unique.
ImportantSi vous souhaitez restaurer la page d'authentification (pour pouvoir accéder à votre portal quand le serveur de votre fournisseur d'identité tombe en panne), vous pouvez ajouter la clé /Auth.aspx?skipssoredirect=true
après le nom de domaine de votre portail dans la barre d'adresse du navigateur.
- Cliquez sur le bouton Enregistrer.
- La section Les métadonnées du fournisseur de service ONLYOFFICE s'affichera.
- Vérifiez si les paramètres sont accessibles au public en cliquant sur le bouton Télécharger le fichier XML des métadonnées du fournisseur de services. Le contenu du fichier XML doit s'afficher.
Le fichier xml est d'habitude utilisé pour configurer le fournisseur d'identité Shibboleth, mais ce n'est pas nécessaire parce que le script install.sh a activé DynamicHTTPMetadataProvider
(le fournisseur d'identité Shibboleth va télécharger le fichier xml à la première demande de connexion).
Vérifier le fonctionnement du fournisseur de services ONLYOFFICE avec le fournisseur d'identité Shibboleth
Le script install.sh a créé 4 utilisateurs qui peuvent tester le fonctionnement du fournisseur de services ONLYOFFICE avec le fournisseur d'identité Shibboleth.
Email |
Nom d'utilisateur |
Mot de passe |
Commentaire |
student1@{your_idp_domain} |
student1 |
password |
Standard |
student2@{your_idp_domain} |
student2 |
password |
Without givenName |
student3@{your_idp_domain} |
student3 |
password |
With umlauts |
staff1@{your_idp_domain} |
staff1 |
password |
Uniquement les champs obligatoires |
Se connecter à ONLYOFFICE sur le côté du fournisseur de service
- Passez à la page d'authentification ONLYOFFICE par ex. https://myportal-address.com/Auth.aspx).
- Cliquez sur le bouton Authentification unique (le texte sur le bouton peut varier si vous avez indiqué un autre texte pendant la configuration du fournisseur de service ONLYOFFICE). S'il n'y a aucun bouton, l'authentification unique n'est pas activé.
- Si tous les paramètres sont correctement configurés, vous serez redirigé vers le formulaire de connexion au fournisseur d'identité Shibboleth:
- Saisissez le nom d'utilisateur et le mot de passe du compte fournisseur d'identité Shibboleth (nom d'utilisateur: student1, mot de passe: password) et activez Don't Remember Login.
- Si vos identifiants sont corrects, une nouvelle fenêtre s'affiche. Autorisez la transmission des informations en cliquant sur le bouton Accept.
- Si tout est correct, vous serez redirigé sur la page d'accueil du portail (l'utilisateur manquant est créé automatiquement, ou les données sont mis à jour si le fournisseur d'identité a apporté des modifications).
Profils des utilisateurs qui sont créés via l'authentification unique
La possibilité de modifier les profils des utilisateurs qui sont créés via l'authentification unique est limitée. Les champs comportant des données fournies par le fournisseur d'identité sont marqués désactivé et on ne peut pas les modifier (par ex. Nom
, Prénom
, Email
, Titre
et Emplacement
). On peut modifier ces données uniquement depuis le compte du fournisseur d'identité.
La figure ci-dessous illustre le menu Actions pour un utilisateur SSO:
La figure suivante illustre le profil d'utilisateur SSO à modifier:
Les profils des utilisateurs qui sont créés via l'authentification unique seront indiqués à l'aide d'icône SSO pour les administrateurs du portail.
Pour vous déconnecter du fournisseur d'identité Shibboleth (si vous n'avez pas désactivé l'option Don't Remember Login lors de la connexion), suivez le lien qui ressemble à ceci: https://{shibboleth-idp-domain}/idp/profile/Logout
