- Apps
- Configuration
- Customization
Customization
Customization settings
The Customization settings section opens by default. It allows you to adapt the workspace appearance to your needs. It includes the following subsections: General, Branding, Appearance, and Default templates.
Language and time zone settings
This section allows you to change the language of your workspace for all workspace users and configure the time zone so that all the events will be shown with the correct date and time.
To configure the Language and Time Zone settings,
drop-down the Language list and select the required language to display all workspace pages and notifications,
This setting specifies the default workspace language for new users.
- set the time zone that corresponds to your location from the Time Zone drop-down list,
- click the Save button at the bottom of the section to apply the changes you made.
Welcome Page Settings
This section allows you to change the default title to be displayed on the Sign In page of your workspace. To do that,
- enter the name you like in the Title field (e.g. your company title, its motto, etc.),
- click the Save button at the bottom of the section to apply the changes you made, or click Restore to revert to the default title.
DNS settings
This section allows you to set an alternative URL for your workspace. In the SaaS version, this is a Paid feature (available for the paid Business plan only). By default, your workspace is registered at name.onlyoffice.com. To change it to your own domain name:
- Configure your domain name to point to the workspace server by setting up the appropriate DNS records with your registrar. Please contact your registrar from whom you purchased the domain name to find out how to do it. Add a DNS CNAME entry, such as, for example: team.ourcompany.com - intranet.onlyoffice.com (for the US West (Oregon) region).
- After setting up your DNS CNAME entry, click the Send request button in the DNS settings section to send your request to our support team. The https://helpdesk.onlyoffice.com/ page will open in a new browser tab. Enter the details of your request and click Submit.
- After the request is processed, your custom domain name will be displayed in the DNS settings section.
Workspace renaming
This section allows you to change the name part of your workspace URL address that appears next to onlyoffice.com so that your workspace is available at newname.onlyoffice.com. In the SaaS version, this is a Paid feature (available for the paid Business plan only). Enter the desired name in the New space name field and click the Save button.
Configure deep link
This section allows you to select if you want to provide a choice when handling documents in a mobile browser. Users can be offered (or not) the choice of opening the file in a browser or in the mobile app.
Select the necessary option: 'Provide a choice (web or app)', 'Open in web only', or 'Open in app only' and click the Save button.
AI services management
This section allows you to control the activation of AI features across the workspace and ONLYOFFICE editors. When AI services are disabled:
- The AI settings section is hidden from the navigation,
- AI agents become unavailable to all users (with their interaction history preserved),
- Paid AI services are no longer accessible.
All interaction history with the AI is securely saved and fully restored upon re-enabling AI services.
Select the Enable or Disable radio button and click the Save button to apply the changes.
Branding
The Branding subsection of the Customization settings allows you to replace branding elements used in the workspace interface with your own ones. You can use your company name in the text elements (such as tooltips, message boxes, etc.) as well as replace the default favicon and logos with your own logo.
- Enter your Brand name in the text entry field to change all the titles and messages in the workspace interface where the default value is used replacing it with the one you specified.
- If you want to use a text logo instead of an image logo, enter your text in the Generate logo from text field and click the Generate button below - all the logos below will change correspondingly.
Replace the image Logos (for the Light and Dark interface themes) displayed in your workspace:
- Logo for the workspace header (422x48) - this logo appears in the upper left corner of every workspace page.
- Logo for the compact left menu (56x56) - this logo appears in the upper left corner in the compact mode on a small screen.
- Logo for the Login page and emails (772x88) - this logo appears on the Sign In page of your workspace.
- Favicon (32x32) - this logo appears in the address bar or tab of a web browser when the workspace is opened in it, or on the bookmarks panel if you have added the workspace address to the bookmarks.
The following logos are available for the Developer version only:- Logo for the editors header (172x40) - this logo appears in the upper left corner of the online editors launched.
- Logo for the editors header - embedded mode (172x40) - this logo appears in the upper left corner of your workspace documents embedded into web pages.
Click the Change Logo link below the logo you want to replace. In the Windows Explorer window, browse for the necessary image file and click the Open button. The image will be uploaded and displayed in the corresponding Logo field.
We recommend that you use images in the PNG format with a transparent background. To improve your logos legibility and make their outline clearly distinguishable, you also need to optimize them for use on dark or light backgrounds. The image sizes are shown for the Retina displays. For the displays with standard resolutions, the logo width and height will be resized accordingly upon upload. - click the Save button at the bottom of the section to apply the changes you made.
To return to the default settings, click the Restore button.
The following sections are available for the server version only.
The Company info settings section is used to specify your company information displayed in the About this program window of your workspace and on the About page in the online editors.
- Use the Show the About window checkbox to hide or show the About this program window.
- Enter your company name, email address, phone number, website URL address and postal address into the corresponding fields.
- Click the Save button at the bottom of this section.
The Additional resources section is used to choose if you want to display links to additional resources.
Clear the elements you want to hide and leave the ones you want to display selected:
- Show Feedback & Support link - is used to hide or show the link to the Feedback and Support form which is used to contact the ONLYOFFICE support team.
- Show link to Video Guides - is used to hide or show the link to the web page with training videos.
- Show link to Help Center - is used to hide or show the link to the Help Center page.
Appearance
The Appearance subsection of the Customization settings allows you to change the default color palette of your workspace interface so that it suits your company brand. To do that,
- switch between the available Standard colors. The Preview section below displays the appearance of your workspace for light and dark interface themes.
- select the color which suits you best.
- click the Save button on the bottom of the screen to apply the selected color.
You can also choose custom colors:
- click the Plus icon in the Custom section to open the New color scheme screen.
- click the Plus icon next to the Accent section to open the color palette, choose the necessary color and click Apply. This color is used for items of the navigation menu, settings tabs, switchers.
- click the Plus icon next to the Buttons section to open the color palette, choose the necessary color and click Apply. This color is used for buttons in dialog windows.
- click the Save button on the New color scheme screen to save the custom color scheme.
- click the Save button on the bottom of the main screen to apply the created custom color scheme.
You can also edit or delete the created custom scheme.
Default templates
This section allows you to replace the default blank files that your workspace uses when a user creates a new document, spreadsheet, or presentation. By uploading your own template files, you can ensure that all newly created documents start with your preferred layout, styles, or content.
To replace a default template:
- Locate the document type whose default template you want to replace: Blank document, Blank spreadsheet, Blank presentation, or Blank form.
- Click the
icon on the right. - Choose the location to upload a template from: Upload from the storage or Upload from device, browse for and select the replacement file.
- Once a template has been uploaded, click the
icon again to manage it: you can replace the current template, preview it, download it to your computer, or reset it to the default values.
