- Docs
- Configuration
- Enterprise
- Docker version
- Connecting MsSQL database to ONLYOFFICE Docs
Currently, there are no Docker variables that allow connecting with MsSQL; the user must perform the steps manually. The steps to connect MsSQL database to ONLYOFFICE Docs are as follows:
Install ONLYOFFICE Docs:
sudo docker run -i -t -d -p 80:80 --name onlyoffice \ onlyoffice/documentserver-ee -
Install MsSQL on the same or a separate server:
sudo docker run -p 8080:1433 -d --name mssql \ -e "ACCEPT_EULA=Y" \ -e "MSSQL_SA_PASSWORD=onlYoff1ce" \ mcr.microsoft.com/mssql/server:2022-latest -
Run the script located at
/var/www/onlyoffice/documentserver/server/schema/mssql/createdb.sql:sudo docker exec mssql /opt/mssql-tools/bin/sqlcmd -S localhost -U sa -P onlYoff1ce -Q "CREATE DATABASE onlyoffice;" sudo docker exec mssql /opt/mssql-tools/bin/sqlcmd -S localhost -U sa -P onlYoff1ce -Q "GO" sudo docker exec mssql /opt/mssql-tools/bin/sqlcmd -S localhost -U sa -P onlYoff1ce -i /var/www/onlyoffice/documentserver/server/schema/mssql/createdb.sql -
Change the parameters responsible for establishing a connection in
local.jsonand switch Document Server to mssql:sudo docker exec -it onlyoffice bash nano /etc/onlyoffice/documentserver/local.json { "services": { "CoAuthoring": { "sql": { "type": "mssql", "dbHost": "mssql_ip_or_hostname", "dbPort": "8080", "dbName": "onlyoffice", "dbUser": "sa", "dbPass": "onlYoff1ce" ... supervisorctl restart all
