Customising calendar colours
Assigning different colours to your calendars helps you distinguish between events at a glance and group related calendars. For example, you can assign a single colour to all project-related or shared calendars to locate events quickly or to prioritise them. Refer to this guide for further detail.
Quick Start
To assign a colour to an existing calendar, follow the steps below:
  1. Sign in to your portal.
  2. Click the Calendar icon icon in the upper-right corner.
  3. All your calendars are displayed on the left. Hover over the required calendar and click the Edit Calendar icon - pencil icon that appears to open the Edit Calendar window.
  4. Click the Colour swatch to assign a different colour to your calendar, and the Text Colour swatch to select a different colour for the text within the calendar events.
  5. Click Save to apply the changes.
The same procedure applies to assigning or changing the colour of other calendars.
Additional Information
Assigning a custom colour
TTo assign a custom colour that is not available on the colour palette, enter its sRGB value in the designated field and click the swatch next to it. Then click Save in the Edit Calendar window to apply a custom colour.
An sRGB colour value is a hexadecimal number prefixed by a hash mark and is case-insensitive. A comprehensive list of sRGB values is available here.
Creating a new calendar and assigning a colour
Follow the steps below:
  2. Click the Calendar icon icon in the right upper corner.
  3. Click the arrow next to Create New and select Calendar.
  4. In the Create New Calendar window, enter a name for the new calendar, set the alert time, and add users for sharing if applicable.
Then follow the instructions above to assign a colour to the new calendar.
