Create lists
To create a list in a text box,
  1. place the cursor to the position where a list will be started (this can be a new line or the already entered text),
  2. open the settings panel by
  3. switch to the TEXT tab and swipe up to see all the settings,
  4. tap the Bullets & Numbers option and select the necessary list type:
    • the first tab contains Numbers list types to create an Ordered list with digits or letters:
      Numbered list
    • the second tab contains Bullets list types to create an Unordered list with markers:
      Bulleted list
    • the third tab contains Custom list types. Select one of the following options to load the image:
      Custom list
      • Picture from Library Picture from Library option will open the Media Library where you can select the necessary file.
        Note: you must have appropriate permissions on your device Media Library.
      • Picture from URL Picture from URL option will open the Link Settings panel where you can enter the necessary image web address in the Image URL field and tap the INSERT IMAGE button.
      Images will be scaled according to the font size.
  5. close the text settings panel by tapping the Close settings panel arrow on the right.
  6. now each time you press the Enter key Enter key at the end of the line a new ordered or unordered list item will appear. To stop that, tap the Backspace key key and continue with the common text paragraph.
You can also change the text indentation in bulleted and numbered lists using the Decrease Indent Decrease Indent icon and Increase Indent Increase Indent icon icons on the TEXT tab.
