Changing application settings
To access the Document Editor advanced settings,
  2. tap the arrow next to the Application Settings Application Settings menu item.
Currently, the following advanced settings are available:
  • Unit of Measurement allows specifying what units are used in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
  • Spell Checking allows enabling or disable the spell checking function.
  • Nonprinting Characters allows displaying or hide nonprinting characters in the document text.
  • Hidden Table Borders allows displaying or hiding table borders. If you enable this option, the hidden table borders will be displayed as dotted lines in the document text.
  • Comments display allows displaying or hide Comments and/or Resolved Comments. If you enable these options, the comments will be highlighted in the document text.
  • Dark theme allows switching to dark interface mode. The dark theme colors vary from black to light-gray providing a comfortable interface for working in low-light conditions.
  • Macros Settings allows choosing if you want to enable all macros with or without a notification, or disable all macros.
