Apply formatting presets
To apply one of the available text formatting presets,
  1. place the cursor within the paragraph you need, or select several paragraphs you want to apply one of the formatting presets to,
  2. open the text and paragraph settings panel by
    • tapping the Edit object icon at the top or bottom toolbar, or
  3. switch to the Paragraph tab,
  4. select the preset you need from the Paragraph style list (swipe it up to see more styles),
    Paragraph Styles settings
    The following formatting presets are available: Book Title, Caption, Emphasis, Heading 1-9, Intense Emphasis, Intense quote, Intense Reference, List paragraph, No spacing, Normal, Quote, Strong, Subtitle, Subtle Emphasis, Subtle Reference, Title, Footnote text.
  5. return to the previous screen by tapping the Back arrow on the left and close the paragraph settings panel by tapping the Close settings panel arrow on the right.
