Adding hyphenation
Hyphenation is used to separate words at the end of lines with a '-' sign in a linguistically correct way.
To add hyphenation:
  1. Tap the Settings icon Settings icon in the right corner of the top toolbar.
  2. Select the Layout icon Layout menu item.
  3. Activate the Auto hyphenation switcher. The hyphenation will be applied automatically.
  4. To delete hyphenation, deactivate the Auto hyphenation switcher.
