- Docs
- Installation et réglage
- Développeur
- Version sous Docker
- Connecter la base de données Oracle à ONLYOFFICE Docs
Currently, there are no Docker variables that allow connecting with Oracle; the user must perform the steps manually. The steps to connect Oracle database to ONLYOFFICE Docs are as follows:
Install ONLYOFFICE Docs:
sudo docker run -i -t -d -p 80:80 --name onlyoffice \ onlyoffice/documentserver-de -
Install Oracle on the same or a separate server:
sudo docker run --name oracle -p 8080:1521 -p 8081:5500 \ -e ORACLE_PASSWORD=admin \ -e APP_USER=onlyoffice \ -e APP_USER_PASSWORD=onlyoffice \ -d gvenzl/oracle-xe:21-slim -
Download a script for creating tables and copy it to the container; afterwards, create a database and run the script:
wget https://github.com/ONLYOFFICE/server/raw/master/schema/oracle/createdb.sql sudo docker cp ./createdb.sql oracle:/ sudo docker exec oracle sqlplus -s onlyoffice/onlyoffice@//localhost/xepdb1 @/createdb.sql -
Change the parameters responsible for establishing a connection in
local.jsonand switch Document Server to mssql:sudo docker exec -it onlyoffice bash nano /etc/onlyoffice/documentserver/local.json "services": { "CoAuthoring": { "sql": { "type": "oracle", "dbHost": "oracle_ip_or_hostname", "dbPort": "8080", "dbName": "xepdb1", "dbUser": "onlyoffice", "dbPass": "onlyoffice" ... supervisorctl restart all
