Artikel zum Thema:
Schließen
Schließen
Select cell background color
To apply a background color to a certain cell/cell range or change the current one,
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Cell option in the pop-up menu,
  3. tap the Fill Color icon Fill Color option to open the color palette panel,
  4. select the necessary color on the Theme Colors or Standard Colors palette (swipe it up to see more colors),
    Cell Background settings
To clear the background color of a certain cell, use the No Fill No Fill icon on the Standard Colors palette.
Schließen
