Artikel zum Thema:
Schließen
Schließen
Set slide parameters
You can change a slide size for all the slides in the presentation. To do that:
  2. select the Presentation Settings icon Presentation Settings menu item,
  3. tap one of the following options: Standard (4:3) or Widescreen (16:9).
  4. use the Back arrow Back arrow on the left to return to the previous screen.
Schließen
