Artikel zum Thema:
Schließen
Schließen
Preview your presentation
To preview your currently edited presentation:
  • in the slide list on the left, select the slide you want to start the preview from,
  • tap the Preview icon icon at the top toolbar,
  • swipe left to advance the following slide, swipe right to return to the preceding slide,
    Note: if you enabled only the Delay option for the transitions between slides in the slide settings, the slides will advance automatically in a specified time interval during the presentation preview. If you enabled both the Start On Click and Delay options, the slides will advance automatically in a specified time interval, but you will also be able to swipe left to advance from a currently displayed slide to the next.
  • once the last slide of the presentation is reached, a black screen appears informing you that the presentation is finished. Tap the screen to exit from the Preview.
Schließen
