Artikel zum Thema:
Schließen
Schließen
Change slide layout
To customize your presentation, you can change the slide layout for each separate slide. To change a slide layout:
  1. in the slide list on the left, tap the slide you want to apply a new layout to,
  2. open the slide settings panel by
  3. tap the Layout menu item,
  4. select the necessary layout (swipe up to see more layouts),
    Layout gallery
    Note: currently, the following layouts are available: Title Slide, Title and Content, Section Header, Two Content, Comparison, Title Only, Blank, Content with Caption, Picture with Caption, Title and Vertical Text, Vertical Title and Text.
Schließen
