Artikel zum Thema:
Schließen
Schließen
Change application settings
To access the Document Editor advanced settings,
  2. tap the arrow next to the Application Settings Application Settings menu item.
Currently, the following advanced settings are available:
  • Unit of Measurement allows to specify what units are used in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
  • Spell Checking allows to enable or disable the spell checking function.
  • Nonprinting Characters allows to display or hide nonprinting characters in the document text.
  • Hidden Table Borders allows to display or hide hidden table borders. If you enable this option, the hidden table borders will be displayed as dotted lines in the document text.
  • Commenting display allows to display or hide Comments and/or Resolved Comments. If you enable these options, the comments will be highlighted in the document text.
Schließen
