Artikel zum Thema:
Schließen
Schließen
Apply font decoration styles
To apply the formatting to the text, select it and open the text and paragraph settings panel by:
On the Text tab, use one of the available settings. Use the Back Back icon on the left to return to the previous settings section.
Text settings
Bold Bold - tap this icon to make the font bold giving it more weight.
Italic Italic - tap this icon to make the font italicized giving it some right side tilt.
Underline Underline - tap this icon to make the text underlined with the line going under the letters.
Strikethrough Strikethrough - tap this icon to make the text struck out with the line going through the letters.
Tap the Additional formatting option. Use one of the following options:
Text advanced settings
  • Strikethrough is used to make the text struck out with the line going through the letters.
  • Double Strikethrough is used to make the text struck out with the double line going through the letters.
  • Superscript is used to make the text smaller and place it to the upper part of the text line, e.g. as in fractions.
  • Subscript is used to make the text smaller and place it to the lower part of the text line, e.g. as in chemical formulas.
  • Small Caps is used to make all letters lower case.
  • All Caps is used to make all letters upper case.
  • Letter Spacing is used to set the space between the characters. Tap Minus icon or Plus icon icons to decrease or increase the current value.
Schließen
