Artikel zum Thema:
Schließen
Schließen
Set paragraph line spacing
Set the line height within a paragraph
  1. put the cursor within the paragraph you need, or select several paragraphs or the whole text,
  2. open the text and paragraph settings panel by
  3. on the Text tab, swipe up to see all the settings,
  4. tap the Line Spacing option,
  5. select the necessary line height value,
    Paragraph line spacing settings
Set the amount of space between paragraphs
  3. switch to the Paragraph tab,
  4. tap the Advanced settings menu item,
  5. use the corresponding options to achieve the desired results:
    • Before/After - set the amount of space before/after the paragraph using the Minus icon or Plus icon icons to decrease or increase the current value.
    • First Line - set the offset from the left side of the page for the first line of the paragraph using the Minus icon or Plus icon icons to decrease or increase the current value.
    • Space Between Paragraphs - turn this option off in case you don't need any space between paragraphs of the same style.
      Paragraph spacing settings
Schließen
