Skip to main content
Creating or deleting sheets
Create a sheet​
By default, a newly created spreadsheet has a single sheet. To add a new one, tap the Add sheet Plus icon located to the left of the sheet navigation panel below the current worksheet.
Manage sheet options​
To work with an existing sheet, tap the sheet tab to open the pop-up menu. The menu contains the following options:
  • Format — sets font formatting.
  • Duplicate — creates an exact copy of the selected sheet.
  • Delete — removes the sheet.
  • Move — opens the sheet list view to reorder the sheets.
  • Hide — hides the sheet without deleting it.
  • Protect — restricts changes to the sheet contents.
Tap the Open settings arrow at the end of the menu to access more options:
  • Tab color — changes the color of the sheet tab. Pick a color from Theme, Standard, or set your own Custom color.
  • Calculate sheet — recalculates all formulas on the active sheet.
Pop-up menu
