Skip to main content
Mobile presentation viewer
Using ONLYOFFICE Documents for iOS you can open presentations in the view mode. In such a case you will be able to view presentations, view presentation information, search for text and print the presentation.
Preview your presentation​
To start the presentation preview, tap the Play button button. The slides will be shown one by one.
If you want to quit presentation preview, swipe down and select Close.
View presentation information​
To access the detailed information about the currently edited presentation:
  1. Tap the Tools icon Tools icon in the right corner of the top toolbar.
  2. Select the Presentation Info Presentation Info menu item.
The presentation information includes the file creation date and author name.
Search for certain text​
  1. Tap the Find icon Find icon at the top toolbar to activate the Find panel.
    Search panel
  2. Enter your inquiry into the data entry field.
  3. Specify search parameters by tapping the Search options icon Search Options icon on the left and selecting the necessary options:
    • Match case - is used to find only the occurrences typed in the same case as your inquiry (e.g. if your inquiry is 'Editor' and this option is selected, such words as 'editor' or 'EDITOR' etc. will not be found).
  4. Tap the Search caption next to the entry field - all the occurrences of the required text will be highlighted in yellow.
  5. Use arrow buttons to navigate through the found occurrences towards the beginning of the presentation (if you tap the Left arrow button icon) or towards the end of the presentation (if you tap the Right arrow button icon) from the current position.
Print out the presentation​
  2. Select the Print Print menu item.
  3. Specify the necessary Printer Options:
    • If no printer is selected, tap Select Printer to choose an AirPrint Printer.
    • Set the number of copies you need to print tapping the Plus icon or Minus icon icons.
  4. Tap Print.
A PDF file generated on the basis of the opened presentation will be printed out.
