Inserting page breaks
Insert a page break at the current cursor position
- Tap the
icon at the top toolbar to open the new object insertion panel.
- Switch to the Other tab.
- Select the
Page Break option.
Insert a page break before the selected paragraph
Put the cursor within the paragraph you need.
Open the Paragraph Settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Paragraph option in the pop-up menu.
- tapping the
Tap the Advanced settings menu item.
Turn the Page Break Before option on.
Adjust other pagination options
The Advanced settings section of the Paragraph Settings panel contains three more pagination options. Swipe up to see them:
- Orphan Control — is turned on by default and used to prevent a single line of the paragraph (the first or last) from appearing at the top or bottom of the page.
- Keep Lines Together — is used to keep lines together so that only whole paragraphs will be moved to the new page (i.e. there will be no page break between the lines within a single paragraph).
- Keep with Next — is used to prevent a page break between the selected paragraph and the next one.
