Navigating through your document
Navigate through your document
To scroll your document, swipe up/down. If the document is zoomed in, you can also swipe right/left. You can also touch and hold close to the right edge of the document until the scroll bar appears. The page indicator at the bottom of the screen shows the current page number.
To zoom in the document, use the stretch gesture: place two fingers on the screen and move them apart. The indicator displays the current zoom value as you move your fingers until you reach the maximum zoom level.
To zoom out the document, use the pinch gesture: place two fingers on the screen and move them together. The indicator displays the current zoom value as you move your fingers until you reach the minimum zoom level.
To switch to the Mobile View, tap the Tools icon at the top right corner and enable the
Mobile View switcher. In this mode, page margins are removed and the text is reflowed to fit the screen width, making it easier to read and edit without zooming in.
