Skip to main content
Graphic annotations and markup
The Document Editor supports graphic annotations and markup. Make additional notes or highlight important information right in the editor.
note
iOS 14 or later is required.
To add a drawing,
  1. Tap the Add item symbol to open a panel for adding items.
  2. Tap the Drawing Drawing option.
  3. Select the required tool: a pencil, a marker or a highlighter marker.
    Tools
  4. Select the required color via the circle to the left. You can choose out of the theme colors, standard colors or customize your color.
  5. Create your drawing. Tap it to change its size by dragging the squares at its edges.
