- Mobile Apps
- Android
- Mobile web editors
- Document Editor web version
- Selecting background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one,
- put the cursor within the paragraph you need, or select several paragraphs or the whole text,
- open the text and paragraph settings panel by
tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
tapping the
- switch to the PARAGRAPH tab,
- tap the Background option to open the color palette panel (swipe it up to see more colors),
select the necessary color on the Theme Colors or Standard Colors palette, or create your own Custom Color,
go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
tap the
button to apply the color to the selected text.
- close the paragraph settings panel by tapping the
arrow on the right.
To clear the background color of a certain paragraph, use the
No Fill icon on the Standard Colors palette.
