Skip to main content
Manage existing sheets
Move sheets​
To move an existing sheet, touch and hold the sheet tab you wish to move, then drag it to a new location. The selected sheet will be moved.
Move sheets
Rename sheets​
To rename an existing sheet, tap the current sheet tab once so that the pop-up menu appears, then tap the Rename option. In the Rename sheet window that opens, enter the desired sheet name and tap ACCEPT.
Rename sheets
Hide/Unhide sheets​
If you have a lot of sheets, you can hide some of them you don't need for the moment to facilitate the work. To do that, tap the current sheet tab once to access the pop-up menu with the Hide option, then tap it.
To display a hidden sheet, tap the current sheet tab once or double-tap an inactive tab so that the pop-up menu appears, then tap the Show option, and select the sheet you want to unhide.
Pop-up menu local
Duplicate sheets​
To duplicate an existing sheet, tap the current sheet tab once to access the pop-up menu with the Duplicate option, then tap it.
Change tab colors​
To differentiate the sheets, you can assign different colors to the sheet tabs. To change the tab color, tap the current sheet tab once so that the pop-up menu appears, then tap the Tab color option. In the Tab color panel, select the necessary color on the Theme colors or Standard colors palette or create your own Custom color. If you don't want to use any fill, tap the No fill icon Without filling option.
Tab color local
  1. tap the Custom color icon in the Custom colors section.
  2. using the color palette, choose the necessary color and select its hue level,
    Custom color
  3. tap the OK button to apply the color to the selected text.
    The added color will also be placed in the Custom colors section, where the recently used custom colors are located.
