Skip to main content
Insert images
Add an image​
  1. select the worksheet you want to put the image onto,
  3. switch to the Other tab icon Other tab,
  4. tap the Image icon Image option and select one of the following options to load the image,
    • the Picture from Library local Picture from library option to open the Media Library where you can select the necessary file.
      note
      You must have appropriate permissions on your device Media Library.
    • the Picture from URL icon Picture from link option will open the Link settings panel where you can enter the necessary image web address into the Image URL field and tap the Insert image button.
    • the Make photo icon Make photo option will open the default camera app. Take a photo and press OK.
    • the Insert from icon Insert from option allows you to select an image from smartphone's files or from cloud storages.
      note
      To access cloud storage, you must be logged in to it and have the necessary rights.
The image will be added. Now you can change its properties and position.
Adjust image settings​
When the image is selected, you can open the shape/image settings panel to change the shape of the image, adjust its border size and color, or change the image position as related to other objects.
  1. select the image by tapping it,
  2. open the settings panel by
    • tapping the Edit icon local icon at the top or bottom toolbar, or
  3. switch to the Shape and tap the necessary menu item: Style, Change shape, or Advanced settings. Use the Return icon on the left to return to the previous settings section.
    The Style section allows you to enable the following options:
    • Border style - set the border:
      • Stroke - switch the toggle to enable or disable border display.
      • Size - set the border size by dragging the slider.
      • Color - select the border color on the palette.
      • Border type - select one of the available border types.
      Border style
      Use the Shape style icon shortcut icon on the bottom toolbar to quickly access shape type settings.
    The Change shape section allows you to change the shape of the image replacing the rectangular shape with another one selected from the menu. The shape of the image will change correspondingly.
    Change shape
    The Advanced settings section allows you to enable the following options:
    • Size - set the image's size:
      • Width and Height - define image's dimentions in a specifit measurement.
      • Lock aspect ratio - switch the toggle to preserve the original image aspect ratio.
      • Units of measurement - selecet one of the available option: cm, pt, inch.
  4. switch to the Image and tap the necessary menu item:
    • The Replace image allows you to replace the current image with another one.
      Use the Replace image icon shortcut icon on the bottom toolbar to quickly access replace image settings.
    • The Arrange section allows you to change the selected image position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
  5. close the shape/image settings panel by tapping the Close settings panel cross on the left.
Remove the image​
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete icon local option in the pop-up menu, or
  • open the shape settings panel by tapping the Edit icon local icon at the top or bottom toolbar and use the Remove shape button.
