Apply cell style
You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset:
select a cell, a range of cells or the whole worksheet,
open the Cell settings panel by
- tapping the
icon at the top or bottom toolbar, or
- tapping the
option in the pop-up menu and choosing the Cell menu item,
- tapping the
swipe up to see the Cell style palette and tap the style you want to apply.
return to the previous screen by tapping the
arrow on the left and close the cell settings panel by tapping the
icon on the left.
