Navigate through your spreadsheet
To navigate between sheets, use the sheet navigation panel below the current worksheet. Tap the necessary sheet tab to switch to the sheet.
To navigate between sheets, tap the icon on the bottom toolbar to open the navigation panel and choose the necessary sheet. Tap the
icon to open a list of sheets and select the one you want to open.
To navigate between cells, use the Next cell and Previous cell
buttons located on the bottom toolbar.
To scroll a sheet, swipe up or down, left or right.
To zoom in a sheet, use the stretch gesture: place two fingers on the screen and move them apart.
To zoom out a sheet, use the pinch gesture: place two fingers on the screen and move them together.
To exit the editor, tap the icon in the upper left corner.
