Skip to main content
Manage slides
Create new slides​
To create a new slide, tap the Insert object button in the slide list.
Insert slide
A new slide will be inserted after the selected one in the slides list.
Duplicate slides​
To duplicate a slide:
  1. double tap the necessary slide in the slides list,
  2. tap the Duplicate slide option in the context menu.
The duplicated slide will be inserted after the selected one in the slide list.
Move slides​
To move an existing slide:
  1. touch and hold the necessary slide in the slides list,
  2. without lifting your finger, drag the slide to the necessary place in the list.
Hide slides​
To hide an existing slide:
  2. tap the Hide slide option in the context menu.
To show the hidden slide:
  1. double tap the hidden slide in the slides list,
  2. tap the Show slide option in the context menu.
Delete slides​
To delete an unnecessary slide:
  2. tap the Delete slide option in the context menu.
