Skip to main content
Insert images
Add an image​
  1. select the slide where you want the image to be put,
  3. switch to the Other tab Other tab,
  4. tap the Picture icon Image option and select one of the following options to load the image:
    • the Picture from Library local Picture from library option will open the Media Library where you can select the necessary file.
      You must have appropriate permissions on your device Media Library.
    • the Picture from URL Picture from link option will open the Link settings panel where you can enter the necessary image web address into the Image URL field and tap the Insert image button.
    • the Make photo icon Make photo option will open the default camera app. Take a photo and press OK.
    • the Insert from icon Insert from option allows you to select an image from smartphone's files or from cloud storages.
      To access cloud storage, you must be logged in to it and have the necessary rights.
The image will be added. Now you can change its properties and position.
Adjust the shape of the image and its border​
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
  1. select the image by tapping it,
  2. open the Shape settings panel by
    • tapping the Edit object icon at the top or bottom toolbar, or
  3. tap the necessary menu item: Style, Replace, Reorder, or Align. Use the Return arrow on the left to return to the previous settings section.
    The Style section allows you to enable the following options:
    • Border style - set the border:
      • Stroke - switch the toggle to enable or disable border display.
      • Size - set the border size by dragging the slider.
      • Color - select the border color on the palette.
      • Border type - select one of the available border types.
      Image border
    The Replace section allows to replace the current image shape with another one selected from the menu. The shape of the image will change correspondingly.
    Reshape image
    The Reorder section allows to set the selected image position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
    The Align section allows to align the image on the slide. To learn more, please refer to the Manipulate objects section of this guide.
  4. close the shape settings panel by tapping the Close settings panel cross on the right.
Remove the image​
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete icon local option in the pop-up menu, or
  • open the shape settings panel by tapping the Edit object icon at the top toolbar, then use the Remove shape button at the Shape tab.
