Select, cut, copy, paste text and objects
Set the insertion point
To position the cursor, touch a text line within the text box.
Paste previously copied text/object,
Delete the next character within the line of text,
Edit text (i.e. open the text settings panel),
- Select the next character,
- Select all objects on the slide.
Select text and objects
To select an object (shape, image, or chart), tap it. To select a text box, tap its border.
When you select an object, the pop-up menu appears that contains the following options:
Cut the selected text/object,
Copy the selected text/object,
Delete the selected text or object,
Edit the selected text or object (i.e. open the text/object settings panel).
Cut, copy, paste text and objects
To cut, copy and paste text passages/objects within the current presentation, use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same presentation.
Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same presentation.
Paste – put the cursor within a text box where you want to paste the previously copied text fragment or double-tap the slide where you want to paste the previously copied object and use the Paste option from the pop-up menu. The text will be inserted at the current cursor position. The object will be inserted onto the currently selected slide. The data can be previously copied from the same presentation.
