Skip to main content
Mobile presentation viewer
Mobile presentation viewer​
Using Documents app for Android you can open presentations in the view mode. To start the presentation preview, tap the Play button button.
To manage slides, use the navigation buttons located on the top:
  • Close - to exit from the view mode;
  • Return icon or swipe right - to return to the preceding slide;
  • Play icon - to start playback. Presentation slides will switch automatically according to the transition parameters;
  • Advance icon or swipe left - to advance the following slide.
    Preview mode
Once the last slide of the presentation is reached, a black screen appears informing you that the presentation is finished. Tap the screen to exit from the Preview.
