Download and print your document
Download the document
To download a document in a selected format, you should locally open the file by tapping on it in the On Device section and follow these steps:
- tap the
Settings icon in the right corner of the top toolbar,
- tap the
Download as... menu item,
- tap one of the available file formats: DOCX, PDF, ODT, DOTX, PDF/A, OTT, RTF, TXT,
- specify the path where the file will be saved.
Export the document
To export a document in a selected format, you should locally open the file by tapping on it in the On Device section and follow these steps:
- tap the
- tap the
Export menu item,
- select the transfer method and recipient.
Send a copy
To send a copy of the file with the same format and content via Bluetooth, messengers, email, etc., you should locally open the file by tapping on it in the On Device section and follow these steps:
- tap the
- tap the
Send a copy menu item,
Print the document
To print the current local document, opened in the On Device section,
- tap the
- tap the
Print menu item to enter the preview mode,
- at the top of the screen choose either an available Printer or tap on the Save as PDF option to generate a PDF file on the basis of this document,
- in the drop-down menu
specify the following parameters:
- number of copies - enter the required number of copies of the document;
- number of pages - choose either a range of pages, filling the textfield in the following way: (e.g. 1-5, 8, 11-13), or tap on each checkbox below to mark the pages you want to print;
- page size - select one of the suggested paper formats;
- color - choose either black and white print or color print (only for supporting printers);
- two-sided printing - this option allows to print on both sides of a sheet of paper (only for supporting printers);
- page orientation - choose from landscape and portrait options,
- tap the
button to initialize printing.
