Skip to main content
Protect documents with a password
To protect your documents in the Document Editor:
  1. Tap the Settings icon Settings icon in the right corner of the top toolbar.
  2. Tap the Protection icon Protection menu option.
  3. Choose whether you want to Encrypt File or to Protect Document.
To encrypt a file and to restrict unauthorized access to it:
  1. tap the Encrypt file Encrypt File menu item,
  2. enter the required password and verify it,
    Encrypt file
    Please note that the password cannot be restored. Please keep it in a safe place so as not to forget it.
  3. save the changes by tapping the Accept icon button in the top right corner, close the settings panel and save the document.
Next time you open this document you will need to enter the password:
Protected file window
To change or delete the password in the Document Editor:
  3. Disable the Set password switcher to delete the password.
  4. Enter and verify the new password to change it.
  5. Apply the changes by tapping the Accept button in the upper right corner, close the settings panel, and save the document.
To protect a document and restrict access rights to it:
  1. tap the Protect document icon Protect document menu option,
  2. enable the Set password switcher. Enter the required password and verify it,
    Protect document
  3. choose the allowed editing rights for the document: No changes (Read only), Filling forms, Tracked changes or Comments.
  4. save the changes by tapping the Accept icon button in the top right corner.
To Unprotect and remove access restrictions:
  2. tap the Protection icon Protection menu option,
  3. tap the Protect document icon Unprotect menu option,
  4. enter the password into the corresponding Unprotect document window and tap OK.
