Insert column breaks
When editing a document that has a multi-column layout, you can specify where a new column should start.
To insert a column break at the current cursor position,
- tap the
- switch to the
Other tab, and tap the
Breaks menu option,
- select the
Column break option,
To remove the added section break, place the cursor at the beginning of the text that followed it and press the key on the on-screen keyboard.
