Skip to main content
Using the Find and Replace function
Search for certain text​
  1. Tap the Settings icon Settings icon in the right corner of the top toolbar.
  2. Tap the Find icon Find and replace option to activate the Find panel.
    Search panel
  3. If necessary, you can specify search parameters by tapping the three dots icon Search Options icon on the right.
    The Options panel opens. Turn on the necessary switchers:
    Search options panel local
    • Case sensitive - is used to find only the occurrences typed in the same case as your inquiry (e.g. if your inquiry is 'Editor' and this option is selected, such words as 'editor' or 'EDITOR' etc. will not be found).
    • Whole words - is used to find only the occurrences of the entire word (e.g. if your inquiry is 'Editor' and this option is selected, such words as 'Editorial' or 'Edit' etc. will not be found).
    • Highlight results - is used to highlight all the found occurrences of the required text.
    When ready, tap the Cross icon icon in the upper left corner.
  4. Enter your inquiry into the data entry field.
    Search panel
  5. Use arrow buttons to navigate through the found occurrences towards the beginning of the document (if you tap the Left arrow button icon) or towards the end of the document (if you tap the Right arrow button icon) from the current position.
Replace the found matches​
  1. Tap the three dots icon Search Options icon on the left to open the Find and replace settings panel.
  2. Tap the Find and replace menu item, change the search parameters, if necessary, and tap the cross icon in the upper left corner. The Find panel will change:
    Find and Replace panel
  3. Enter the replacement text into the second data entry field.
  4. Use arrow buttons to navigate through the found occurrences and tap Replace to replace the currently selected occurrence.
  5. To replace all the found occurrences, tap the three dots icon Search Options icon on the left to open the Find and replace all settings panel. Tap the Replace all option that appears next to the entry field.
To close the Find panel, tap the Resolve icon button.
