Changing document settings
To access the Document advanced settings:
- Tap the
Tools icon in the right corner of the top toolbar.
- Tap the arrow next to the
Document Settings menu item.
Currently, the following advanced settings are available:
- Document language is used to enable or disable the spell checking function. This option also affects spell-checking operations.
- Show non-printing symbols is used to display or hide nonprinting characters in the document text.
- AI Assistant is used to access the AI-powered features for document editing.
- Word counter is used to display the number of words in the document.
