Add hyperlinks
Add a hyperlink
tap the
switch to the
Other tab,
select the
Link option,
after that the Link settings screen will appear where you can specify the hyperlink parameters:
Link - enter a URL in the format http://www.example.com.
Display - enter a text that will get clickable and lead to the web address specified in the upper field.
noteIf you've selected a text passage before tapping the
icon, the Display field will be filled with the selected text fragment.
tap the checkmark in the upper right corner.
note
To follow the added link, tap the Open Link option in the pop-up menu.
Edit or remove the added hyperlink
tap the Edit Link option in the pop-up menu and perform the actions you need:
- edit your data and tap the checkmark in the upper right corner to save the changes.
- use the Remove link button to delete the added hyperlink.
