Skip to main content
Adding hyphenation
Hyphenation is used to separate words at the end of lines with a '-' sign in a linguistically correct way.
To add hyphenation:
  1. Tap the Settings Settings icon in the right corner of the top toolbar.
  2. Select the Layout Layout menu item.
  3. Activate the Auto hyphenation switcher. The hyphenation will be applied automatically.
  4. To delete hyphenation, deactivate the Auto hyphenation switcher.
