Skip to main content
Select, cut, copy, paste text
Set the insertion point​
To position the cursor, touch a text line in the document.
Pop-up menu
The menu options allow you to:
  • Paste previously copied text/object,
  • Delete the next character within the line of text,
  • Edit text (i.e. open the text/paragraph settings panel),
  • Select the next character,
  • Select all objects in the document.
Select text​
Selection handles
To select an object, tap it.
When you select text or object, the pop-up menu appears that contains the following options:
  • Cut Cut the selected text/object,
  • Copy Copy the selected text/object,
  • Paste Paste previously copied text/object,
  • Delete Delete the selected text or object,
  • Edit Edit the selected text or object (i.e. open the text/object settings panel).
Cut, copy, paste text​
To cut, copy and paste text passages/objects within the current document use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
  • Cut Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same document.
  • Copy Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same document.
  • Paste Paste – find the place in your document where you need to paste the previously copied text fragment/object and use the Paste option from the pop-up menu. The text/object will be inserted at the current cursor position. The data can be previously copied from the same document.
