Articles with the tag:
Close
Close
Download your spreadsheet
Download the spreadsheet
To download the current spreadsheet to your device selecting one of the available formats,
  2. tap the Download Download menu item,
  3. tap one of the available file formats: XLSX, PDF, ODS, CSV.
    Note: if you select the CSV format, all features (font formatting, formulas etc.) except the plain text will not be preserved in the CSV file. The Choose CSV Options window will open. By default, Unicode (UTF-8) is used as the Encoding type. The default Delimiter is comma (,), but the following options are also available: semicolon (;), colon (:), Tab and Space.
    Choose CSV Options
The file will be downloaded and stored on your device.
You Might Also Like This:
Close
