Articles with the tag:
Close
Close
Manage existing sheets
Rename sheets
To rename an existing sheet, tap the current sheet tab once so that the pop-up menu appears, then tap the Rename option. In the Rename Sheet window that opens, enter the desired sheet name and tap OK.
Rename sheets
Hide/Unhide sheets
If you have a lot of sheets, you can hide some of them you don't need for the moment to facilitate the work. To do that, tap the current sheet tab once to access the pop-up menu with the Hide option, then tap it.
To display a hidden sheet, tap the current sheet tab once or double-tap an inactive tab so that the pop-up menu appears, then tap the Unhide option. In a submenu that opens, select the sheet you want to unhide.
Pop-up menu
Duplicate sheets
To duplicate an existing sheet, tap the current sheet tab once to access the pop-up menu with the Duplicate option, then tap it.
You Might Also Like This:
Close
