Articles with the tag:
Close
Close
Apply cell style
You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the More option in the pop-up menu and choosing the Cell menu item,
  3. swipe up to see the Cell Styles palette and tap the style you want to apply.
    Cell styles palette
  4. close the cell settings panel by tapping the Close settings panel arrow on the right.
You Might Also Like This:
Close
