Articles with the tag:
Close
Close
Use the Find function
Search for certain text
  2. tap the Find icon Find option to activate the Find panel,
    Search panel
  3. enter your inquiry into the data entry field,
    Search panel
  4. use arrow buttons to navigate through the found occurrences towards the beginning of the presentation (if you tap the Left arrow button icon) or towards the end of the presentation (if you tap the Right arrow button icon) from the current position.
    To clear your inquiry, use the Clear your inquiry icon to the right of the entry field.
Exit the Find mode
To close the Find panel, tap within the presentation area.
You Might Also Like This:
Close
