Articles with the tag:
Close
Close
Select, cut, copy, paste text and objects
Set the insertion point
To position the cursor, touch a text line within the text box.
Pop-up menu
The menu options allow you to:
  • Paste previously copied text,
  • Delete the next character within the line of text,
  • Edit text (i.e. open the text/paragraph settings panel),
  • if you select the More option, a submenu opens that allows to Add link.
Select text and objects
Selection handles
To select an object (shape, image, or chart), tap it. To select a text box, tap its border.
When you select a text passage or object, the pop-up menu appears that contains the following options: Cut, Copy, Paste, More. If you select the More option, a submenu opens that allows to perform the following actions: Delete the selected text or object, Edit it (i.e. open the text/object settings panel) or Add link (this option is only available for the selected text).
Double-tap a slide in the slide list to open the pop-up menu that contains the following two options: Paste and Edit. The Edit option allows to open the slide settings panel.
Cut, copy, paste text and objects
To cut, copy and paste text passages/objects within the current presentation use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
  • Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same presentation.
  • Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same presentation.
  • Paste – put the cursor within a text box where you want to paste the previously copied text fragment or double-tap the slide where you want to paste the previously copied object and use the Paste option from the pop-up menu. The text will be inserted at the current cursor position. The object will be inserted onto the currently selected slide. The data can be previously copied from the same presentation.
You Might Also Like This:
Close
