Articles with the tag:
Close
Close
Add hyperlinks
  1. place the cursor where you want the link to be added or select the text passage that will get clickable,
  2. choose the More option in the pop-up menu and tap the Add Link menu item or do the following:
    1. tap the Insert object icon at the top toolbar to open the new object insertion panel,
    2. switch to the OTHER tab,
    3. select the Link Link option,
  3. after that the Add Link screen will appear where you can specify the hyperlink parameters:
    • Link - enter a URL in the format http://www.example.com.
    • Display - enter a text that will get clickable and lead to the web address specified in the upper field.
      Note: if you've selected a text passage before tapping the Insert object icon, the Display field will be filled with the selected text fragment.
    • Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to.
    Hyperlink Settings window
  4. tap the INSERT button.
Note: to follow the added link, double-tap it, choose the More option in the pop-up menu and tap the Open Link option.
  1. select the link and open the text and paragraph settings panel by
    • tapping the More option in the pop-up menu and choosing the Edit option,
  2. switch to the HYPERLINK tab and perform the actions you need:
    • edit your data and tap the EDIT LINK button to save the changes.
    • use the REMOVE LINK button to delete the added hyperlink.
You Might Also Like This:
Close
