Chiudi Centro assistenza Documenti Documenti Persone Come organizzare e gestire la documentazione della società? Importa file da fonti diverse Versioni e revisioni in Documenti di online office User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Personal ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs Document Editor Spreadsheet Editor Presentation Editor User Guides about Editors ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors How to edit documents from Nextcloud in ONLYOFFICE Documenti di online office Menu contestuale in Documenti di online office Document collaboration made easy in the online office Documenti Documenti Come modificare il documento collaborativamente online? Come creare un file CSV? Come inserire un documento nel tuo blog? Come organizzare e gestire la documentazione della società? More articles Integra altre risorse in Documenti di online office Gestisci i tuoi documenti con online office Chiavi di autorizzazione Integrating third-party services in the cloud version Versioni e revisioni in Documenti di online office Sending for electronic signature Learning about folder permissions hierarchy Sharing files and folders How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE Managing versions and revisions Sharing documents Personal Personal Managing versions and revisions Sharing documents Languages availabe in ONLYOFFICE Personal How to edit documents from Dropbox in ONLYOFFICE How to edit documents from Google Drive in ONLYOFFICE How to edit documents from Nextcloud in ONLYOFFICE How to edit documents from ownCloud in ONLYOFFICE How to edit documents from Box in ONLYOFFICE How to edit documents from OneDrive in ONLYOFFICE ONLYOFFICE Personal troubleshooting Document collaboration made easy in the online office Real-time co-editing in ONLYOFFICE integrate Nextcloud account Integra altre risorse in Documenti di online office How to edit documents from Nextcloud in ONLYOFFICE Configuring reverse proxy for Nextcloud and ONLYOFFICE editors Integrating ONLYOFFICE with Nextcloud Open or create new files and folders Open or create new files and folders Open or create new files and folders Open or create new files and folders More articles How to integrate ONLYOFFICE with Nextcloud using the app from the official store How to integrate ONLYOFFICE with Nextcloud Configuring ONLYOFFICE connector for Nextcloud You have a Nextcloud account and want to edit your documents using ONLYOFFICE? Follow this step-by-step guide to find out how to edit documents stored in your Nextcloud from the Documents portal module. Connect your Nextcloud account to ONLYOFFICE In the left sidebar of the Documents, just below the text Connect, click on the Nextcloud icon. Specify the connection URL, your user name and password and click Save to connect your NextCloud account. For example, the URL that allows to access your Nextcloud files via WebDAV looks like this: https://yourdomain.com/remote.php/webdav/. This URL address can be found in the following way: sign in to your Nextcloud account, click the Settings icon in the lower left corner and copy the entire URL from the WebDAV field. Then switch to the ONLYOFFICE Documents module and paste the entire copied URL address, including the protocol, into the Connection URL field. Your NextCloud documents will be shown in ONLYOFFICE documents as a folder. Change the folder‘s name if necessary. If you want the NextCloud documents to be visible for anyone, click on the Make shared checkbox and put into the Common Documents folder. If not checked, your NextCloud account will only be visible to you. This step is not available while working in ONLYOFFICE Personal. Click Save. Edit your Nextcloud documents Locate the Nextcloud folder and open it. Browse to the file you want to edit and click it. If necessary, a dialog will tell you that the document will be converted to the OpenOffice XML format for faster viewing and editing. You can choose to keep the original file as well, by checking the Save the file copy in the original format as well box. Click Convert. Click Open when the message appears that your document is successfully converted. Now you can edit your document (if editable). After editing, you can simply close the document and the changes will be saved. Download Host on your own server Available for Docker, Windows and Linux Ti potrebbe essere d'aiuto anche... Chiudi
