Voci con l'etichetta :
Chiudi
Chiudi
Provalo nel cloud
Inviting new users
ONLYOFFICE DocSpace admins can create users within DocSpace itself (selecting the user type), as well as invite users to rooms for collaboration and assign permission levels to them.
When inviting users to DocSpace, the available actions differ depending on the user type:
Section\User type Owner DocSpace admin Room admin Power user User
My documents
Creating, uploading, moving, copying, renaming, downloading, deleting files and folders
Rooms
Viewing all rooms
Viewing own rooms
Viewing rooms the user is invited to
Creating and editing rooms
Pinning rooms to top
Viewing room info (members, history, details)
Inviting users to own room, assigning and changing permission levels of the room members, removing users from the room
Archiving own rooms
Editing someone else's rooms: inviting users, assigning and changing permission levels of the room members, removing users from the room
Archiving someone else's room
Archive
Viewing all rooms
Viewing own rooms
Inviting users to a room, assigning and changing permission levels of members
Restoring or removing someone else's rooms
Restoring or removing own rooms
Trash
Accounts
Inviting "DocSpace admin"
Inviting "Room admin"
Inviting "Power user"
Inviting "User"
Promoting to "DocSpace admin"
Promoting to "Room admin"
Promoting to "Power user"
Demoting "DocSpace admin" to "Room admin"
Disabling "DocSpace admin"
Disabling "Room admin"
Disabling "Power user"
Disabling "User"
Editing or removing users
Room manager settings
DocSpace settings
Removing DocSpace
All other settings
To add users within DocSpace,
  1. Go to the Accounts section on the left.
  2. Use the Invite button in the upper left corner or the Plus icon Plus icon above the list of users.
  3. Select the user type: DocSpace admin, Room admin, Power user, User.
  4. Invite users via the link:
    1. Turn on the Invite via link switcher – the link will be copied to the clipboard.
    2. If you want to change the user type, select the necessary one from the list and use the Copy link icon icon to copy the modified invitation link to the clipboard. You can send the copied link in any convenient way.
      This link is valid for 7 days only.
      Invitation link Invitation link
  5. Alternatively, you can use the Add manually section to add email addresses manually one by one:
    1. Enter a valid email address and click ‘Add’ below or press Enter. In the same way, add several email addresses if necessary.
    2. Change the invitation language if necessary.
    3. Change the user type if necessary.
    4. When ready, click the Send invitation button. Invitations will be sent to the specified email addresses.
      Individual invitation Individual invitation
When a user receives the invitation, they should follow the link, specify their email (if they were invited using Invite via link option), first and last name, and set a password (the password CANNOT be less than 8 and more than 30 characters long).
Invitation Invitation
After that the user can:
  • access DocSpace,
  • view the Rooms and Archive spaces (they are empty if the user was not invited to a room),
  • edit their own profile.
Once the user is invited to a room, they can participate in collaboration. Admins can manage the existing users in DocSpace.
Docker, Windows and Linux
Chiudi
