Voci con l'etichetta :
Chiudi
Chiudi
Change application settings
To access the application settings,
  2. tap the arrow next to the Application Settings Application Settings menu item.
Currently, the following advanced settings are available:
  • Unit of Measurement allows to specify what units are used in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
  • Spell Checking allows to enable or disable the spell checking function.
Chiudi
