Voci con l'etichetta :
Chiudi
Chiudi
Set slide parameters
You can change a slide size for all the slides in the presentation. To do that:
  2. select the Presentation Settings icon Presentation Settings menu item,
  3. tap one of the following options: Standard (4:3) or Widescreen (16:9).
  4. use the Back arrow arrow on the left to return to the previous screen and close the settings panel by tapping the Done caption on the right.
Chiudi
