Voci con l'etichetta :
Chiudi
Chiudi
Collaborative spreadsheet editing
View user list
When a spreadsheet is being edited by several users simultaneously, you can view who are editing the file now.
  1. tap the Collaboration icon Collaboration icon in the right corner of the top toolbar,
  2. select the Users menu item.
The Users panel will open with the list of users who are currently editing the spreadsheet.
Users panel
View Comments
To view comments that have been added to the spreadsheet:
  2. select the Comments menu item.
Comments panel
Note: you can specify if you want to display comments and/or resolved comments on the worksheet. This can be done using the application settings. If you disable displaying comments, the orange marks will not be displayed in the upper right corner of the commented cell, but all comments still can be viewed via the Comments panel.
Chiudi
