Chiudi Centro assistenza ONLYOFFICE Documents for Android Presentation Editor Document Editor complete documentation ONLYOFFICE Documents app for Android Overview Available languages Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information Glossario FAQ Generale Tecnologia Prezzi Enterprise Edition Integration Edition Developer Edition Community Server Print your presentation operazioni con file Creare nuova presentazione o aprire presentazione esistente Creare nuovo documento o aprire documento esistente Creare nuovo foglio di calcolo o aprire un foglio di calcolo esistente Salvare/scaricare/stampare documento Salvare/stampare/scaricare presentazione Salvare/stampare/scaricare foglio di calcolo Visualizzare informazioni sul documento Visualizzare informazioni sul file More articles Visualizzare informazioni sulla presentazione Manage files Open or create new files and folders Share files and folders View document information Change application settings Use the Find and Replace function Save/export/print your document View spreadsheet information Change application settings Use the Find and Replace function Save/export/print your spreadsheet View presentation information Use the Find function Save and export your presentation Change application settings Print your presentation Manage files Open or create new files and folders Share files and folders View document information Use the Find and Replace function Download and print your document View spreadsheet information Use the Find and Replace function Download and print spreadsheet View presentation information Use the Find and Replace function Download your presentation Print presentation Manage files Open or create new files and folders Share files and folders Use the Find and Replace function Change application settings Download and print your document View document information Change spreadsheet settings Change application settings Download and print your spreadsheet View spreadsheet information Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information Manage files Open or create new files and folders Share files and folders Use the Find and Replace function Change application settings Download and print your document View document information Use the Find and Replace function Change spreadsheet settings Change application settings Download and print your spreadsheet View spreadsheet information Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information stampare file Salvare/scaricare/stampare documento Salvare/stampare/scaricare presentazione Salvare/stampare/scaricare foglio di calcolo Save/export/print your document Save/export/print your spreadsheet Print your presentation Download and print your document Download and print spreadsheet More articles Print presentation Download and print your document Download and print your spreadsheet Print your presentation Download and print your document Download and print your spreadsheet Print your presentation Print the presentation To print the current presentation, tap the Tools icon in the right corner of the top toolbar, tap the Print menu item. A PDF file will be generated on the basis of this presentation. It can be printed out. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
